GeoFence Widget
4533
08-21-2013 06:09 AM
HiranZani2
New Contributor III
Hi there,
I have seen several demos where geographic fences are demonstrated within the Operations Dashboard.
Is there a custom widget available for this?
Thanks in advance!
TifPun
Occasional Contributor II
Hi Hiran,
The addin here has some tools for geofence/geoevent that you might find useful.
Tif
Dr__JasemAl-Ali
Hi All,
I am not able to download this widget as the open/download button is dimmed (not active)
Regards,
~Rani
TifPun
Hi Rani,
Yes, addins cannot be downloaded directly from ArcGIS Online. In order to you it you can sign in to your ArcGIS Online org. from Dashboard, enter edit mode of your operational view, then use the Manage Add-ins tool to look up for and add the addin.
Please let me know if that helps,
Tif
Dr__JasemAl-Ali
Hi Tif ,
Thanks for your prompt response.
I could add this widget but I could not use it on my private portal for ArcGIS . Can I get this widget to be used on my private portal ?
~Rani
