ctilly
Custom GP Tool paths
Discussion created by ctilly on Aug 21, 2013
Latest reply on Aug 30, 2013 by AntoJK
I've written a custom tool executable and I've added it to ArcGIS as a script tool using the method discussed here:
http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/index.html#//0001000003t6000000
The tool reads from a config file located in the same directory as the executable.  When ran manually from the command line this application works fine.  However, once I run it as a script tool it fails because it can't find the config file, which it thinks is located in the same directory as ArcGIS in c:\Program Files.
What do I need to do to make it so that it reads the config file relative to where the executable resides and not relative to the host environment of the application housing the script process?
Many Thanks.
Chuck
Outcomes
