AnsweredAssumed Answered
GroupLayer: Layer pointer should be locked before being accessed.
Question asked by kuiperfoliage on Aug 20, 2013
Latest reply on Feb 9, 2014 by kuiperfoliage
I'm experiencing problems when trying to remove a GroupLayer from the Map. It keeps crashing on the NativeLayerPointer with the following error
"Layer pointer should be locked before being accessed." when trying to retrieve the pointer.
Is there a specific way how GroupLayers should be removed ?
How can i provide more debug information to Esri so this can be fixed or resolved? I'm not sure if I can provide a PoC.
Thank you
EDIT 2:
I think it is a threading issue when multiple layers are being added to the GroupLayer, which causes the _lockedOnThreadId, _lockCount to be out of sync, but this is a guess. I'm further investigating.
There should probably be a lock on the '_lockCount' integer.
EDIT 1: Call stack:
System.InvalidOperationException: Layer pointer should be locked before being accessed.
   at ESRI.ArcGIS.Client.Runtime.NativeLayerPointer.get_Ptr()
   at ESRI.ArcGIS.Client.Runtime.NativeLayerPointer.op_Implicit(NativeLayerPointer p)
   at ESRI.ArcGIS.Client.Runtime.NativeGroupLayer.RemoveLayer(Layer layer)
   at ESRI.ArcGIS.Client.Runtime.NativeGroupLayer.ClearChildLayers(IEnumerable`1 layers)
   at ESRI.ArcGIS.Client.Runtime.NativeGroupLayer.Dispose(Boolean disposing)
   at ESRI.ArcGIS.Client.Runtime.NativeLayer.Dispose()
   at ESRI.ArcGIS.Client.Runtime.NativeGroupLayer.Dispose()
   at ESRI.ArcGIS.Client.NativeMap.RemoveLayer(Layer layer)
   at ESRI.ArcGIS.Client.DrawingSurface.RemoveLayer(Layer layer)
   at ESRI.ArcGIS.Client.Map.RemoveMapLayer(Layer layer)
   at ESRI.ArcGIS.Client.Map.Layers_CollectionChanged(Object sender, NotifyCollectionChangedEventArgs e)
   at System.Collections.Specialized.NotifyCollectionChangedEventHandler.Invoke(Object sender, NotifyCollectionChangedEventArgs e)
   at System.Collections.ObjectModel.ObservableCollection`1.OnCollectionChanged(NotifyCollectionChangedEventArgs e)
   at System.Collections.ObjectModel.Collection`1.Remove(T item)
   at XXX.LayerManagement.LayerManager.RemoveLayer(Layer layer) in XXX\LayerManager.cs:line 463
   at XXXViewModel.ExecuteRemoveLayerCmd(Object parameter) in XXXViewModel.cs:line 391
   at DelegateCommand.Execute(Object parameter) in DelegateCommand.cs:line 117
   at Telerik.Windows.Controls.RadMenuItem.ExecuteCommand() in c:\TB\117\WPF_Scrum\Release_WPF\Sources\Development\Controls\Navigation\Menu\RadMenuItem.cs:line 3202
   at Telerik.Windows.Controls.RadMenuItem.OnClickImpl() in c:\TB\117\WPF_Scrum\Release_WPF\Sources\Development\Controls\Navigation\Menu\RadMenuItem.cs:line 1686
   at Telerik.Windows.Controls.RadMenuItem.OnClick() in c:\TB\117\WPF_Scrum\Release_WPF\Sources\Development\Controls\Navigation\Menu\RadMenuItem.cs:line 2330
   at Telerik.Windows.Controls.RadMenuItem.ClickItem() in c:\TB\117\WPF_Scrum\Release_WPF\Sources\Development\Controls\Navigation\Menu\RadMenuItem.cs:line 3722
   at Telerik.Windows.Controls.RadMenuItem.HandleMouseUp() in c:\TB\117\WPF_Scrum\Release_WPF\Sources\Development\Controls\Navigation\Menu\RadMenuItem.cs:line 1667
   at Telerik.Windows.Controls.RadMenuItem.OnMouseLeftButtonUp(MouseButtonEventArgs e) in c:\TB\117\WPF_Scrum\Release_WPF\Sources\Development\Controls\Navigation\Menu\RadMenuItem.cs:line 1999
   at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
   at System.Windows.Input.InputManager.ProcessStagingArea()
   at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
   at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
   at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
Outcomes
