gabrisch
Help with layer file definition query in arcpy.mapping
Discussion created by gabrisch on Aug 20, 2013
Latest reply on Aug 20, 2013 by msayler
Everything seems to work just fine with the code below except that no features draw in the layer that is being queried.  All I want to do is create a jpeg for each record in my geodatabase feature class of point locations.
Is there something wrong with my query syntax?  I cannot figure it out!
try:
    import arcpy, sys, traceback
    print "Working..."
    mxdPath = r"Z:\GISpublic\GerryG\WaterResources\WaterSampleSiteAutoMap\WaterSampleSiteAutoMap2.mxd"
    mxd = arcpy.mapping.MapDocument(mxdPath)
    df = arcpy.mapping.ListDataFrames(mxd)[0]
    lyr = arcpy.mapping.ListLayers(mxd, "WaterSampleSiteMaster", df)[0]
    print lyr.dataSource
    theAttribute = "SiteID"
    #GetAListOfEachAttribute
    listOfAttributes = []
    print "Start cursor"
    rows = arcpy.SearchCursor(lyr.dataSource)
    for row in rows:
        listOfAttributes.append(row.getValue(theAttribute))
    for elm in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT"):
        if elm.name == 'gbglabeler':
            elm = elm
            print elm.name
            break
    for item in listOfAttributes:
        #GBGquery = "\""  + theAttribute + "\" = " + "'" + item + "'"
        GBGquery = '"SiteID" =' + '\''+ item + '\''
        print  "Working on: ",item
        print GBGquery
        lyr.definitionQuery = GBGquery
        elm.text = "Site: " + item
        outputjpg = "Z:\GISpublic\GerryG\WaterResources\WaterSampleSiteAutoMap\SiteMaps\\" + item + ".jpg"
        arcpy.RefreshActiveView()
        arcpy.mapping.ExportToJPEG (mxd, outputjpg)
    print "done"
except arcpy.ExecuteError:
    msgs = arcpy.GetMessages(2)
    arcpy.AddError(msgs)
#If the error is with the script, or with python, find error and report it to the screen...
except:
    tb = sys.exc_info()[2]
    tbinfo = traceback.format_tb(tb)[0]
    pymsg = "PYTHON ERRORS:\nTraceback info:\n" + tbinfo + "\nError Info:\n" + str(sys.exc_info()[1])
    msgs = "ArcPy ERRORS:\n" + arcpy.GetMessages(2) + "\n"
    arcpy.AddError(pymsg)
Outcomes
