gyetmanesri-ca-esridist
Line features disappearing when published to AGOL
Discussion created by gyetmanesri-ca-esridist Employee on Aug 20, 2013
Latest reply on Aug 21, 2013 by gyetmanesri-ca-esridist
I have a set of point, line, and polygon features representing water lines and features. When I try and publish them to ArcGIS Online from ArcGIS for Desktop 10.2, three of the four line feature classes do not show up on the map. In fact, if I preview the map service in ArcMap the line features do not show up (the point feature classes and polygon feature class work fine).
I have run check and repair geometry on all of the feature classes, which are stored in a File Geodatabase.
I created a new empty Geodatabase, copied all of the feature classes to it using ArcCatalog, changed the ArcMap document to point to the new Geodatabase source, and published again. The result was the same: the line feature classes do not show up.
Oddly, if I change the data access capabilities from feature access to tiled mapping, the line features appear in the preview. However, I need to publish these as features, not tiles.
Any suggestions?
TIA,
Greg
Outcomes
