AnsweredAssumed Answered
PopupInWebmapForEditing Error
Question asked by ysw.wijaya on Aug 15, 2013
Latest reply on Aug 21, 2013 by ysw.wijaya
i tried arcgis android sample PopupInWebmapForEditing, and tried to tap to add a new point feature and edit an existing point feature i got this message.
08-15 20:10:10.505: E/MapCore(823): Frame_buffer_OGL::init_ FrameBufferOGLTexture2D: gl error = 502
08-15 20:10:10.558: A/libc(823): Fatal signal 11 (SIGSEGV) at 0xdeadbaad (code=1), thread 836 (Thread-78)
i follow the instructions
on the
http://resources.arcgis.com/en/help/android-sdk/concepts/index.html#/Popup_In_Web_Map_For_Editing_Sample/011900000030000000/
Right click the sample project and select Android Tools > Add Support Library
Accept packages to install and click Install
Under Android Dependencies you should see the android-support-v4.jar file library
Right click the sample project and select Properties
Select the Java Build Path on the left hand side then select Order and Export in the Java Build Path tabs
Make sure Android Dependencies is checked
Run the application
i'm using
1. Eclipse Java EE IDE for Web Developers. Helios Service Release 2
2. Android 4.3 emulator
is there any solution for this kind of error?
Outcomes
