Fro a .Net project, I neeed to update/edit the records (values not attribute name) of a geodatabase table. I have searched around but it is hard to find a piece of sample code for it. At http://forums.esri.com/Thread.asp?c=93&f=985&t=97308, I only found a piece of ArcObjects code that used ADODB. If you have an idea how to do, please share. Thanks.
Since I will only need to edit SDE Oracle GDB tables (not feature classes), I can use Syste.Data.OracleClient to connect the GDB tables, and then work on the editing. So, case closed.
