Row 'isNull()' problem
604
08-07-2013 09:31 AM
KevinYanuk
I am attempting to loop over a centerline shapefile and pull out specific values per field value to set as a new row value in another shapefile.
However, the code fails when the returned value is null, even when using the isNull() method as so:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//002z0000001q000000
if not self.centerline.isNull(suffix):     self.newStreet.S_suffix = self.centerline.getValue(suffix)
Has anyone run into this problem with this method before?
JimCousins
MVP Regular Contributor
I have not run into this specifically, but what about putting in some error handling to allow your code to continue on past these rows?
Implement the Try-Except block statement.
Regards,
Jim
JimCousins
Regards,
Jim
KevinYanuk
Regards,
Jim
Thanks for the reply - that is what I had to do:
                try:
                    if not self.centerline.isNull(name):
                        self.newStreet.S_name = self.centerline.getValue(name)
                except:
                    pass
                try:
                    if not self.centerline.isNull(prefix):
                        self.newStreet.S_prefix = self.centerline.getValue(prefix)
                except:
                    pass
                try:
                except:
                    pass
                try:
                    if not self.centerline.isNull(type):
                        self.newStreet.S_type = self.centerline.getValue(type)
                except:
                    pass
Although, not the prettiest, I suppose it works.
JamesCrandall
MVP Frequent Contributor
da.SearchCursor has some options too:
fields = ['fld1', 'fld2', 'fld3']
for field in fields:
   where = field + " IS NOT NULL"
   try:
       with arcpy.da.SearchCursor(fc, fields, where) as cursor:
          for row in cursor:
              value = row[0]
              print field + ": " + str(value) #or use "value" to do something
   except Error:
       pass
del row, cursor
note: I first tested for "IS NULL" values and simply printed them out and it correctly listed/printed the fields and the null value.  So then I just altered it to "IS NOT NULL" to get the opposite result, printing all values for each field that is not null.  I did not fully research this for better option, do additional testing or determine if this is actually incorrect --- so I am very open to critique of the above!
RhettZufelt
Does this work for you?
if self.centerline.getValue(suffix) is not None:
R_
