ipeebles
Search Results in Data Grid then zoom to feature (point) Problem
Discussion created by ipeebles on Aug 6, 2013
Latest reply on Aug 11, 2013 by vinaybansal
I have set up a search function that allows a user to type in a value then perform a search for a point feature.  Results will post in a data grid.  When I click on the record in the data grid I can zoom to a point.  However, when I click another record to zoom to that record, the map zooms in further.  Is there a way to prevent this from happening?  I need to keep the same zoom extent for all features, rather than zooming in further as each record is clicked.  Here is the code that I have so far:
Does not include variable declaration or function init (
Code:
function doFind() {
        //Set the search text to the value in the box
        findParams.searchText = dojo.byId("searchText").value;
  if (findParams.searchText == 0)
   alert("There are no tree species found. Please type in a valid species code");
  else
        findTask.execute(findParams,showResults2);
    function showResults2(results) {
        //This function works with an array of FindResult that the task returns
  map.graphics.clear();
  var markerSymbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 12, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0, 0, 0]), 1), new dojo.Color([0, 255, 255, .5]));
        var lineSymbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASH, new dojo.Color([0, 255, 255]), 1);
        var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0, 0, 0, 1]), 2), new dojo.Color([255, 255, 0, 0.5]));
  if(results.length == 0)
   alert("There are no tree species found.");
  else
   //create array of attributes
   var items = dojo.map(results,function(result){
    var graphic = result.feature;
    switch (graphic.geometry.type) {
   case "point":
    graphic.setSymbol(markerSymbol);
    break;
   case "polyline":
    graphic.setSymbol(lineSymbol);
    break;
   case "polygon":
    graphic.setSymbol(polygonSymbol);
    break;
   map.graphics.add(graphic);
   return result.feature.attributes;
        //Create data object to be used in store
        var data = {
          identifier: "AssetID",  //This field needs to have unique values
          //label: "Asset ID", //Name field for display. Not pertinent to a grid but may be used elsewhere.
          items: items
        //Create data store and bind to grid.
        store = new dojo.data.ItemFileReadStore({ data:data });
        var grid = dijit.byId('grid');
        grid.setStore(store);
        //Zoom back to the initial map extent
        map.centerAndZoom(center, zoom);
    //Zoom to tree when user clicks a row
    function onRowClickHandler(evt){
  var TreePoint = grid.getItem(evt.rowIndex).AssetID;
        var SelectedTreePoint;
        dojo.forEach(map.graphics.graphics,function(graphic){
          if((graphic.attributes) && graphic.attributes.AssetID === TreePoint){
            SelectedTreePoint = graphic;
            return;
        var TreePointExtent = SelectedTreePoint.geometry;
  map.centerAndZoom(TreePointExtent, .001);
Outcomes
