zlm0922
bath Addjoin problem from new pythoner ?
Discussion created by zlm0922 on Aug 2, 2013
I wrote a python code to AddJoin a personal geodatabases (zlm-07.31.mdb) containing 23 featureclasses to a table view (fcode) for every featureclass .They have a field in common (DB).when I run the code in a featureclass, it works well . running the code below.
#!/usr/bin/python
# -*- coding: GB2312 -*-
# Import system modules
import sys, string, os, arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create(9.3)
gp.OverWriteOutput = 1
# Set workspace to folder containing personal geodatabases
gp.Workspace =  r"F:\ysss"   #sys.argv[1]   #
fcode = "F:\\ysss\\zlm-07.31.mdb\\fcode"  # sys.argv[2]
# Identify personal geodatabases
pgdbs = gp.ListWorkspaces("","Access")
for pgdb in pgdbs:
    # Set workspace to current personal geodatabase
    gp.workspace = pgdb
    datasets = gp.listdatasets()
    for ds in datasets:
      gp.Workspace = ds
      fcs = gp.ListFeatureClasses()
      for fc in fcs:
        if str(fc)=="HYDPY":
         Output_Layer =""
         # Local variables...
         #RESPY = "F:\\ysss\\zlm-07.31.mdb\\sx500\\HYDLN"
         #RESPY__3_ = "F:\\ysss\\zlm-07.31.mdb\\sx500\\HYDLN"
         Output_Layer = fc+"_Layer"
        # fcode = "F:\\ysss\\zlm-07.31.mdb\\fcode"
         #ttt = "HYDLN_Layer"
        # RESPY_Layer = "HYDLN_Layer"
         #Output_Layer_Name = "HYDLN_Layer"
         #fc = "HYDLN"
         # Process: Add Field...
         gp.AddField_management(fc, "name278", "TEXT")
         # Process: Make Feature Layer...
         gp.MakeFeatureLayer_management(fc, Output_Layer)
          # Process: Add Join...
         gp.AddJoin_management(Output_Layer, "DB", fcode, "DB", "KEEP_ALL")
         # Process: Calculate Field...
         gp.CalculateField_management(Output_Layer, fc+ ".name278", "[fcode.??]", "VB", "")
         # Process: Remove Join...
         gp.RemoveJoin_management(Output_Layer, "fcode")
print gp.GetMessages()
gp.AddMessage(gp.GetMessages())
However,when running code loop through among 23 featureclasses, the error message is
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000728: Field DB does not exist within table
Failed to execute (AddJoin).
Please kindly advise how to modify the code.
Thank you.
#!/usr/bin/python
for pgdb in pgdbs:
    gp.workspace = pgdb
    for ds in datasets:
      gp.Workspace = ds
      for fc in fcs:
        #if str(fc)=="HYDPY":
         Output_Layer =""
         #fc = "HYDLN"
Outcomes
