function init() { //This sample requires a proxy page to handle communications with the ArcGIS Server services. You will need to //replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic //for details on setting up a proxy page. esri.config.defaults.io.proxyUrl = "/proxy"; esri.config.defaults.io.alwaysUseProxy = false;
//This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://myserver/ArcGIS/rest/services/Geometry/GeometryServer");
map = new esri.Map("map");
dojo.connect(map, 'onLoad', function (map) { initToolbar(map); });
