var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer")
map.addLayer(basemap);
var lubbock = new esri.layers.ArcGISDynamicMapServiceLayer("http://maps101.gis.halff.com/ladon/rest/services/Lubbock/LubbockCCTVAssets/MapServer", {
opacity: 0.8
map.addLayers([lubbock]);
dojo.connect(map, 'onLayersAddResult', function (results) {
var toc = new agsjs.dijit.TOC({
map: map,
layerInfos: [{
layer: lubbock,
title: "Lubbock CCTV Assets"
}, 'tocDiv');
toc.startup();
lubbock.setVisibleLayers([9]);
function mapReady(map) {
dojo.connect(map, "onClick", executeIdentifyTask);
//create identify tasks and setup parameters
identifyTask = new esri.tasks.IdentifyTask("http://maps101.gis.halff.com/ladon/rest/services/Lubbock/LubbockCCTVAssets/MapServer/");
identifyParams = new esri.tasks.IdentifyParameters();
identifyParams.tolerance = 3;
identifyParams.returnGeometry = true;
identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE;
identifyParams.width = map.width;
identifyParams.height = map.height;
function executeIdentifyTask(evt) {
identifyParams.geometry = evt.mapPoint;
identifyParams.mapExtent = map.extent;
var deferred = identifyTask.execute(identifyParams);
deferred.addCallback(function (response) {
// response is an array of identify result objects
// Let's return an array of features.
return dojo.map(response, function (result) {
var feature = result.feature;
feature.attributes.layerName = result.layerName;
if (result.layerName === 'Survey Points') {
console.log(feature.attributes.OBJECTID);
var template = new esri.InfoTemplate("Survey Points", "<br/> Unique ID: ${UNIQUE_ID}<br/> X Coord: ${X_COORD}<br/> Y Coord: ${Y_COORD}<br/> Z Coord: ${Z_COORD}<br/> Type:${Type}<br/> Status: ${Status}<br/> Data Source: ${DATA_SOURCE}<br/> Shape: ${SHAPE}<br/> Survey Date: ${SURVEY_DATE}<br/>Alternate Name: ${ALT_NAME}");
feature.setInfoTemplate(template);
else if (result.layerName === 'CCTV Observations') {
var template = new esri.InfoTemplate("CCTV Observations", "<br/> CCTV Route: ${CCTV_ROUTE}<br/> CCTV Distance: ${CCTV_DISTANCE}<br/> CCTV Code: ${CCTV_CODE}<br/> CCTV Value Percent: ${CCTV_VALUE_PERCENT}<br/> CCTV Clock From: ${CCTV_CLOCK_FROM}<br/> CCTV Clock To: ${CCTV_CLOCK_TO}<br/> CCTV Grade: ${CCTV_GRADE} <br/>CCTV Continuous: ${CCTV_CONTINUOUS}<br/> CCTV Observation Type:${CCTV_OBS_TYPE}<br/> CCTV Observation:${CCTV_OBSERVATION}<br/> CCTV Remark:${CCTV_REMARK} <br/>Shape:${SHAPE}<br/> CCTV Attachment:${CCTV_Attach}");
else if (result.layerName === 'Manholes') {
var template = new esri.InfoTemplate("Manholes", "${*}")
else if (result.layerName === 'Inlets') {
var template = new esri.InfoTemplate("Inlets", "${*}")
else if (result.layerName === 'Infalls') {
var template = new esri.InfoTemplate("Infalls", "${*}")
else if (result.layerName === 'Outfalls') {
var template = new esri.InfoTemplate("Outfalls", "${*}")
else if (result.layerName === 'Channel Features') {
var template = new esri.InfoTemplate("Channel Features", "${*}")
else if (result.layerName === 'Pipe Features') {
var template = new esri.InfoTemplate("Pipe Features", "${*}")
else if (result.layerName === 'Playa Centroids') {
var template = new esri.InfoTemplate("Playa Centroids", "${*}")
else if (result.layerName === 'Pipes') {
var template = new esri.InfoTemplate("Pipes", "${*}")
else if (result.layerName === 'Flumes') {
var template = new esri.InfoTemplate("Flumes", "${*}")
else if (result.layerName === 'Dams') {
var template = new esri.InfoTemplate("Dams", "${*}")
else if (result.layerName === 'Channels') {
var template = new esri.InfoTemplate("Channels", "${*}")
else if (result.layerName === 'CCTV Routes') {
var template = new esri.InfoTemplate("CCTV Routes", "${*}")
else if (result.layerName === 'Virtual Links') {
var template = new esri.InfoTemplate("Virtual Links", "${*}")
else if (result.layerName === 'Stormwater Systems') {
var template = new esri.InfoTemplate("Stormwater Systems", "${*}")
else if (result.layerName === 'Asset Footprints') {
var template = new esri.InfoTemplate("Asset Footprints", "${*}")
else if (result.layerName === 'Playa Lakes') {
var template = new esri.InfoTemplate("Playa Lakes", "${*}")
map.infoWindow.setFeatures([deferred]);
map.infoWindow.show(evt.mapPoint);
return feature;
