AnsweredAssumed Answered
replaceDataSource working on single mxd, but not multiple.
Question asked by davidarnold on Jul 25, 2013
Latest reply on Jul 29, 2013 by rzufelt
Im very new to Python, and Im trying to write a script to trawl through a folder of mxds and replace an incorrectly named dataset.  I have a script that works on a single map document (below)
current_mxd = arcpy.mapping.MapDocument ("CURRENT") df = arcpy.mapping.ListDataFrames (current_mxd) for dataframes in df:     print "DATAFRAME = " + dataframes.name + "\n" + "LAYERS: "     lyrs = arcpy.mapping.ListLayers (dataframes)     for layers in lyrs:         print "  " + layers.name     for broken in arcpy.mapping.ListBrokenDataSources (dataframes):         print broken.name + " source is missing"         if broken.dataSource == r"C:\Student\MapScripting10_0\Maps\PlainsView.gdb\East_Timort":                broken.replaceDataSource (r"C:\Student\MapScripting10_0\PlainsView.gdb","FILEGDB_WORKSPACE","East_Timor", False) del broken del layers del dataframes del mxd arcpy.RefreshTOC()
But when I try and create this to run over multiple map documents in a folder (below), I get no change.
import arcpy, os start = r"C:\Student\MapScripting10_0\Maps" for root, dirs, files in os.walk(start):     for mapDoc in files:         if mapDoc.endswith(".mxd"):             path = os.path.abspath(os.path.join(root,mapDoc))             mxd = arcpy.mapping.MapDocument(path)             print "\n" + "Map Document = " + path             df = arcpy.mapping.ListDataFrames (mxd)             for dataframes in df:                 print "  DATAFRAME = " + dataframes.name + "\n" + "LAYERS: "                 lyrs = arcpy.mapping.ListLayers (dataframes)                 for layers in lyrs:                     print "    " + layers.name                 del layers                 for broken in arcpy.mapping.ListBrokenDataSources (dataframes):                     print broken.name + " source is missing"                     print "    Original source = " + broken.dataSource                     if broken.dataSource == r"C:\Student\MapScripting10_0\Maps\PlainsView.gdb\East_Timort":                         print "    Found. Attempting to fix."                         osource = r"C:\Student\MapScripting10_0\Maps\PlainsView.gdb"                         nsource = "Timor"                         broken.replaceDataSource (osource,"FILEGDB_WORKSPACE",nsource, False)                 del broken                 del layers             del dataframes             del df             del mxd #    mxd.saveACopy(os.getcwd() + "\\" + mapDoc[:-4] + "_new.mxd")       del mapDoc del root del dirs del files arcpy.RefreshTOC() arcpy.RefreshActiveView()
Where am I going wrong? If someone could steer me in the right direction it would be greatly appreceated.
Regards,
David
Outcomes
