New to ArcObjects 10
474
07-23-2013 10:51 AM
NeedHelp
Having trouble creating custom buttons for 10.0 from 9.3.
I know most of my code will work, but when I run the snippits:
GetMxDocumentFromArcMap & GetActiveVewFromArcMap both return Nothing.
So it's impossible to do anything further when you can't get a valid reference to the MxDoc or Active view.
My previous code used to have:
Private m_application As IApplication
But in 10.0 I get an error with that line and changed it to:
Private m_application As ESRI.ArcGIS.Framework.IApplication
Could somebody post some sample code or sample project to help me get started??
KenBuja
MVP Esteemed Contributor
What is the value that you're setting m_application to? If you're creating an Add-in, then you can use
Private m_application As ESRI.ArcGIS.Framework.IApplication = My.ArcMap.Application
NeedHelp
Still hoping to get a bit of help.
Even when I use the Snippet "GetMxDocument from ArcMap" Nothing gets returned.
Is there something basic I'm missing??
KenBuja
NeedHelp
WOW... your awesome!!  That was exactly what the problem was.
Thanks so much.
Wonder if it's a common issue for new to '10 programmers, or just me 🙂
KenBuja
Glad to help. We all start as beginners!
Don't forget to click the check to mark the thread answered (and the up arrow to mark it as helpful).
