AnsweredAssumed Answered
name the output shapefile after the working folder
Question asked by helenak on Jul 18, 2013
Latest reply on Jul 21, 2013 by Wayne_Whitley
Hello
System Vista, ArcGIS 9.3
I want to make the name of the output shape file (out_name) the same as the working folder (Zoon).
Therefore, the output shape files will not have the same name even if they are generated by shape files in different folders.
Please kindly advise if this is possible.
If so, please kindly instruct how to modify the code below and thank you.
Thank you
Elaine
################################################## ######################## ##AddJoin feature layers to a feature layer ##Elaine Kuo ##01 July 2013 ################################################## #######################  #Import standard library modules import arcgisscripting import os  #Create the Geoprocessor object gp = arcgisscripting.create(9.3) gp.QualifiedFieldNames = "UNQUALIFIED"  #Set the input workspace workingfolder= "H:/temp_D/NP_1067/Apodiformes-34_R/Zoon" gp.Workspace = workingfolder  #Set the output workspace outputfolder= "H:/temp_D/test_1" outWorkspace= outputfolder  source_fc = "H:/temp_D/NP_1067/A_grid.shp"  #Get a list of the featureclasses in the input folder fcs = gp.ListFeatureClasses()  gp.Toolbox = "Data Management"  # Make a FeatureClass layer     gp.MakeFeatureLayer_management (source_fc, "source_lyr")  # A counter to separate the first time through the loop from all other times counter = 0 # Loop through every item in the list that was just generated for fc in fcs:     if counter == 0:         # set up first Layer for AddJoin         gp.AddJoin_management("source_lyr", "GID", fc, "GID", "KEEP_ALL")     else:         # set up second and following Layers for AddJoin         gp.AddJoin_management("source_lyr", "A_grid.GID", fc, "GID", "KEEP_ALL")     counter += 1  # convert a layer to a featureclass  out_name = gp.Describe("source_lyr").name out_name = gp.ValidateTableName(out_name, outputfolder) out_shape = outputfolder + "/" + out_name + ".shp"  gp.CopyFeatures_management ("source_lyr", out_shape)      # delete Field  (need to clean up with a lot more ID fields that the code you have below since now there are 50 GID values.) fieldList = gp.ListFields(out_shape) for field in fieldList:     if field.name[1:4] == "ID_":         gp.deletefield (out_shape, field.name)  # Don't bother removing 50 joins, just kill the layer # clear memory of layers gp.Delete("source_lyr")      gp.AddMessage(gp.GetMessages()) print gp.GetMessages()
Outcomes
