Hi,i work with my team in a standalone application using ArcObjects. I simply try to: - create a new .mxd;- insert 2 new data frames; - add a new feature layers to each added data frame. Each new feature layer points to a feature class in a local geodb (at file system).The problem occurs after mxd is created: geodb at file system is locked then can't be renamed or deleted.Can someone help me??This is my code:
Public Sub TestLock()
Dim pDocClassOut As MxDocumentClass = Nothing
Dim pObjectCopy As IObjectCopy = Nothing
Dim appl As IApplication = Nothing
Dim iNumLock As Integer = 0
Using comRel As ESRI.ArcGIS.ADF.ComReleaser = New ESRI.ArcGIS.ADF.ComReleaser()
Try
'apre mxd di output
Dim strPathOutput As String = String.Empty
pDocClassOut = New MxDocumentClass()
appl = TryCast(pDocClassOut.Parent, IApplication)
appl.Visible = False
Dim mxDoc As IMxDocument = TryCast(appl.Document, IMxDocument)
comRel.ManageLifetime(mxDoc)
Dim objFactory As IObjectFactory = TryCast(appl, IObjectFactory)
Dim actContView As IContentsView = mxDoc.ContentsView(0)
actContView.Activate(appl.hWnd, mxDoc)
mxDoc.CurrentContentsView = actContView
Dim strNomeGeoDb As String = "E:\Temp\23TestLock.gdb"
Dim strNomeFC() As String = {"CDB_FCLTY_POINT", "CDB_FCLTY_LINE", "CDB_FCLTY_POINT"}
'apre geodb
'Dim gdbFactType As Type = GetType(FileGDBWorkspaceFactoryClass)
'Dim typeClsID As String = gdbFactType.GUID.ToString("B")
'Dim wksFactory As IWorkspaceFactory = DirectCast(objFactory.Create(typeClsID), IWorkspaceFactory)
Dim factoryType As Type = Type.GetTypeFromProgID("esriDataSourcesGDB.FileGDBWorkspaceFactory")
Dim wksFactory As IWorkspaceFactory = CType(Activator.CreateInstance(factoryType), IWorkspaceFactory)
comRel.ManageLifetime(wksFactory)
Dim pWks As IWorkspace = wksFactory.OpenFromFile(strNomeGeoDb, 0)
comRel.ManageLifetime(pWks)
For idx As Integer = 0 To 2
'apre FC
Dim outFWKS As IFeatureWorkspace = CType(pWks, IFeatureWorkspace)
comRel.ManageLifetime(outFWKS)
Dim newFC As IFeatureClass = outFWKS.OpenFeatureClass(strNomeFC(idx))
'comRel.ManageLifetime(newFC)
'crea il DF nella destinazione
If idx <> 0 Then
Dim pUID As New UID
Dim pCmdItem As ICommandItem
' Use the GUID of the Save command
pUID.Value = "{C22579D5-BC17-11D0-8667-0000F8751720}"
pUID.SubType = 3
'comRel.ManageLifetime(pUID)
pCmdItem = appl.Document.CommandBars.Find(pUID)
pCmdItem.Execute()
'comRel.ManageLifetime(pCmdItem)
If pCmdItem IsNot Nothing Then
System.Runtime.InteropServices.Marshal.ReleaseComObject(pCmdItem)
End If
If pUID IsNot Nothing Then
System.Runtime.InteropServices.Marshal.ReleaseComObject(pUID)
End If
End If
'Dim maps As IMaps = CType(TryCast(appl.Document, IMxDocument).Maps, IMaps)
'If idx <> 0 Then
' Dim pMap1 As IMap = New MapClass
' pMap1.Name = "ciccio2"
' maps.Add(pMap1)
' comRel.ManageLifetime(pMap1)
'End If
'Recupera il DF
Dim map As IMap = maps.Item(idx)
map.Name = "Data frame " & idx.ToString()
map.Description = "Descr"
'attiva il dataframe corrente
Dim activeView As IActiveView = mxDoc.ActiveView
activeView.Activate(appl.hWnd)
'comReleaser.Add(activeView)
If TypeOf (activeView) Is IPageLayout Then
mxDoc.ActiveView.FocusMap = map
'comRel.ManageLifetime(mxDoc.ActiveView.FocusMap)
Else
mxDoc.ActiveView = CType(map, IActiveView)
'comRel.ManageLifetime(mxDoc.ActiveView)
End If
'map = mxDoc.ActiveView.FocusMap
'crea il layer
Dim fcLay As IFeatureLayer = DirectCast(objFactory.Create("esriCarto.FeatureLayer"), IFeatureLayer)
'Dim fcLay As IFeatureLayer = New FeatureLayer
fcLay.Name = "Lay" & idx.ToString()
fcLay.FeatureClass = newFC
'comRel.ManageLifetime(fcLay)
'comRel.ManageLifetime(fcLay.FeatureClass)
'aggiunge layer alla mappa
map.AddLayer(fcLay)
If fcLay IsNot Nothing Then
System.Runtime.InteropServices.Marshal.ReleaseComObject(fcLay)
End If
If map IsNot Nothing Then
System.Runtime.InteropServices.Marshal.ReleaseComObject(map)
End If
If newFC IsNot Nothing Then
System.Runtime.InteropServices.Marshal.ReleaseComObject(newFC)
End If
mxDoc.CurrentContentsView = mxDoc.ContentsView(0)
mxDoc.UpdateContents()
'appl.SaveDocument()
appl.SaveAsDocument("E:\DEV EnGIS\Untitled.mxd")
If pWks IsNot Nothing Then
System.Runtime.InteropServices.Marshal.ReleaseComObject(pWks)
End If
If wksFactory IsNot Nothing Then
System.Runtime.InteropServices.Marshal.ReleaseComObject(wksFactory)
End If
Catch ex As COMException
Return
Finally
appl.Shutdown()
'eseguiti in ogni caso anche se si passa per un return
If pDocClassOut IsNot Nothing Then
System.Runtime.InteropServices.Marshal.ReleaseComObject(pDocClassOut)
End If
If appl IsNot Nothing Then
System.Runtime.InteropServices.Marshal.ReleaseComObject(appl)
End If
pDocClassOut = Nothing
pObjectCopy = Nothing
End Try
End Using
GC.Collect()
'End Using
End Sub
