Modifying Python script to work in a toolbox
321
5
07-15-2013 10:00 AM
JacobDrvar
I am new to python scripting and began by creating a specific tool.  The clip works well in either PythonWin 2.7 or ArcToolbox 10.1. Now, I want to modify the script for any feature class. How would I modify the script to input/clip/output any feature class? GetParameterAsText? Then, I intend to add the script to a toolbox. The script is as follows:
#Import system modules
import arcpy
from arcpy import env
#Workspace
env.workspace = "E:\User\MillageCode"
#Variables
input = "Sales_2006.shp"
clip = "EagleHarborSales_temp.shp"
output = "Output_temp5.shp"
#Clip the Sales_2006 shapefile to the EagleHarborSales_temp shapefile
arcpy.Clip_analysis(input, clip, output)
#Info
print arcpy.GetMessages()
Thanks!
So, I have modified the Python script to include the GetParameterAsText function.  But, I receive an error code that statues values are not defined for the input, clip, and output.  The code now reads:
#Import modules
import arcpy, os, sys
#Workspace
arcpy.env.workspace = arcpy.GetParameterAsText(0)
#Variables
input = arcpy.GetParameterAsText(1)
clip = arcpy.GetParameterAsText(2)
output = arcpy.GetParameterAsText(3)
#Clip
#Info
Any suggestions on why the script errors out?
DanPatterson_Retired
shouldn't work, you need \\ instead of \ or append r to the front of the path
JacobDrvar
The E:\User\MillageCode path works in both ArcToolbox and PythonWin.
Any suggestions on the second script?  The error is an ExecuteError: Failed to execute.  Parameters are not valid.  Error 000735: Input, Clip, and Output Features: Value is required.  I thought the values were provided as variables.
print the inputs and outputs to see if what you suggests does indeed work
JacobDrvar
Dan,
The desired results were achieved through the first script.  I loaded the output shapefile created in Python vs. running the clip tool in ArcToolbox.  The results were identical.  I just NEED to get the second script up and running.  Thanks.
This is a copy of the results from the Interactive Window.  I just reran the first script.
Executing: Clip E:\User\MillageCode\Sales_2006.shp E:\User\MillageCode\EagleHarborSales_temp.shp E:\User\MillageCode\Output_temp5.shp #
Start Time: Tue Jul 16 07:35:46 2013
Reading Features...
Cracking Features...
Assembling Features...
Succeeded at Tue Jul 16 07:35:46 2013 (Elapsed Time: 0.00 seconds)
WesMiller
Regular Contributor III
Are you supplying the script with the requested parameters? In PythonWin there is a place to put in the parameters(Arguments). In toolbox you will have to create the parameters.
