Hi
I've notice that each SOE is shutdown if its arcgis service isn't used for a long time.
But I need to build a SOE to check every minute if a record in a table is changed.
Is there a workaround to keep alive a SOE and ensure that it continues to run?
I thought to create a thread to call the SOE through a REST method every minute,
but i don't know if this is a good practice or if there is another solution
designed direcly by "esri".
thank you in advance.
Max
