jordanawhite
Viewshed analysis in forested area
Discussion created by jordanawhite on Jul 2, 2013
Latest reply on Sep 2, 2013 by jeffrey.vanetten
I'm running viewshed analyses based on some countryside footpaths - I'm using a 5m DTM, but I want to incorporate more elements into this viewshed. I'll be converting shapefiles to rasters and assigning a z value so this can be added on top of the DTM.
However, the problem I'm envisaging is that when I add elements where viewshed points are present, this viewshed point will naturally be placed at the same level of the new DTM with added elements. I want to somehow have the viewshed points at the height of the original DTM. For example, if a footpath is going through a forest (which has been added as an element from the original shapefile) I don't want the viewshed point to be on top of this forest, but instead at the DTM "ground level". I understand that there will be no visibility for such instances but I would nonetheless like to keep such points.
I have the viewshed points as a point class and a line class. Perhaps by converting these into rasters then assigning this the DTM z value this can then replace other cells (i.e. where added forestry elements exist).
I feel there's probably a way of doing this in Raster Calculator, but I'm not sure exactly of the pathway to follow.
Any help would be greatly appreciated!
Outcomes
