jsn
Error: SdeParseHandlers::fatalError()
Discussion created by jsn on Jun 28, 2013
When running this command:
Copy "Database Connections\sde Source.sde\\SDE.WSAnno" C:\JOB\SDEConn\To_WriteInstance.sde\SDE.WSAnno FeatureClass
I get the following error message:
       unable to connect socket for URL 'http://www.fgdc.gov/metadata/fgdc-std-0
01-1998.dtd', line 2, char 0
DB_xml_parse_doc: A syntax error was found in the XML document
Executing: Copy "Database Connections\sde Source.sde\\SDE.WSAnno" C:\JOBCON
FIG\SDEConn\To_WriteInstance_As_SDE.sde\SDE.WSAnno FeatureClass
Start Time: Fri Jun 28 14:30:32 2013
Succeeded at Fri Jun 28 14:32:35 2013 (Elapsed Time: 2 minutes 3 seconds)
Anyone with a similar problem?   It looks like the metadata has some issues when copying a layer to SDE 10.1
Outcomes
