Publishing network analyst tool as service.
605
06-26-2013 01:20 PM
NadeemQazi
New Contributor III
I have just started working Network analyst in my recent project.  I have created network analyst data set and than develop a tool that calculates distance between two given point. The tool is shown in the attached file. I run it on ArcMAP it works fine, than i published it on server , however i received following error:
High Unresolved 00082 Output parameter Route in task Model1roadsonemoretry requires a result map service
So I want to know what is this error as I want to use my tool as Geoprocessing service that takes my arguments and returns me the best route  and route length.  Is it must for this network analysis to provide with a result map service or is there any other way to do this.
when i used the option asynchronous and checked view with map service , the service is published, but I am not sure how to use it from my Flex application.
please help.
regards
nadeem
KevinHibma
Your attachment isn't in the post, so I'm just guessing.
Have you done a "select" to pull the output route out from the Solve?
The output of Solve is actually multiple layers. I have a feeling this, as your final output node is why you're getting the 00082 error (a datatype which GP Server can't return, but could draw in a result map service).
I'd recommend going through this help link and comparing what you have to the sample:
http://resources.arcgis.com/en/help/main/10.1/#/Shortest_Route/00570000009q000000/
NadeemQazi
New Contributor III
Sorry , I have now uploaded the model . I need advices 🙂 I am looking on the link u sent to me.may be it would give me an idea.
thanks
regards
nadeem
NadeemQazi
New Contributor III
thanks
regards
nadeem
Dear Kevin H.
Following your advice i used Select Data however i also unchecked  Route as output parameter of my model and it worked. But now it does not draw the line between the given stop rather it gives length of distance between two stops. In case i also want to draw the line than what should i do . I have visited your provided link .the example uses network analysis as service but it does not use any mGP model . Can u please put some light which way is better to use network analysis .1. as GP service or 2 as Network Analysis serviceplease see me attached model with modification.
regards
nadeem
KevinHibma
Based on the model (screen shot), it looks like your final Select is pulling out STOPS.
I think you want it to pull out ROUTES.
Double click the Select inside Modelbuilder and use the drop down to select the routes layer.
This version of the tutorial was written for 10.0, but explains the model a bit more:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/#/GP_service_example_Shortest_route_on_a_street_ne...
The help makes this point:
"Network analysis layers (such as Route) are not supported output parameter data types for ArcGIS Server clients. So the Select Data tool is used to get the Routes sublayer from the Route layer."
