I'm using an AssyncTask to search some information from a MapServer. My objective is to show the results ordered by name, but even when I add the option query.setOrderByFields()
the list comes disordered.The Layer that I want to query has the option "Supports Advanced Queries: True" and if I use the query editor in the ArcGIS REST Services Directory with the orderBy, the results come oredered.Here is my code, Is there any thing wrong??? private class CommunesQueryTask extends
AsyncTask<String, Void, FeatureSet> {
ProgressDialog progress;
boolean isComm;
protected void onPreExecute() {
progress = ProgressDialog
.show(getContext(), "Chargement",
"Veuillez patienter .... tâche de requête est en cours d'exécution");
* First member in parameter array is the query URL; second member
* is the where clause.
protected FeatureSet doInBackground(String... queryParams) {
FeatureSet fs = null;
Query query = new Query();
String url;
if(queryParams.length==0){
isComm=true;
SpatialReference sr = cadastre.getSpatialReference();
query.setGeometry(new Envelope(518566.76294912,
6677527.650037218, 643370.5775897676, 6783333.562810987));
query.setOutSpatialReference(sr);
query.setOutFields(new String[] { "*" });
Map<String,OrderByFields> order = new LinkedHashMap<String,OrderByFields>();
order.put("nomcom", OrderByFields.ASC);
query.setOrderByFields(order);
url = cadastre.getUrl().concat("/9");
}else{
isComm=false;
url=queryParams[1];
order.put("libelle", OrderByFields.ASC);
query.setWhere(queryParams[0]);
QueryTask qTask = new QueryTask(url);
try {
fs = qTask.execute(query);
} catch (Exception e) {
// TODO Auto-generated catch block
e.printStackTrace();
return fs;
return fs;
protected void onPostExecute(FeatureSet result) {
if (result != null) {
Log.i(TAG, "Communes with values");
Graphic[] grs = result.getGraphics();
if (grs.length > 0) {
if(isComm){
String[] comms = new String[grs.length + 1];
commId = new String[grs.length];
comms[0] = "Sélectionnez...";
for (int i = 1; i < comms.length; i++) {
commId[i - 1] = grs[i - 1].getAttributes()
.get("id_comm").toString();
comms = grs[i - 1].getAttributes().get("nomcom")
.toString();
ArrayAdapter<String> spinnerAdapter = new ArrayAdapter<String>(
getContext(),
android.R.layout.simple_spinner_item, comms);
spinnerAdapter
.setDropDownViewResource(android.R.layout.simple_spinner_dropdown_item);
comm.setAdapter(spinnerAdapter);
Log.i(TAG, "Communes loaded: " + commId.length);
}else{
String[] rues = new String[grs.length + 1];
rueId = new String[grs.length];
rues[0] = "Sélectionnez...";
for (int i = 1; i < rues.length; i++) {
rueId[i - 1] = grs[i - 1].getAttributes()
.get("id_voie").toString();
rues = grs[i - 1].getAttributes().get("libelle")
.toString();
rue.setEnabled(true);
getContext(),
android.R.layout.simple_spinner_item, rues);
spinnerAdapter
rue.setAdapter(spinnerAdapter);
Log.i(TAG, "Rues loaded: " + rueId.length);
progress.dismiss();
