_gpTask.ExecuteCompleted -> e.Results.Messagesto Xml file. May be it would be helpful.
<?xml version="1.0" encoding="utf-8"?> <Log> <date_10.06.2013_14_33_06 Name="Executing (ClipFeatures): ClipFeatures "100 Kilometers" "Feature Set"" Error="" /> <date_10.06.2013_14_33_06 Name="Start Time: Mon Jun 10 14:31:03 2013" Error="" /> <date_10.06.2013_14_33_06 Name="Executing (ClipFeatures): ClipFeatures "100 Kilometers" "Feature Set"" Error="" /> <date_10.06.2013_14_33_06 Name="Start Time: Mon Jun 10 14:31:03 2013" Error="" /> <date_10.06.2013_14_33_06 Name="Executing (ClipFeatures): ClipFeatures "100 Kilometers" "Feature Set"" Error="" /> <date_10.06.2013_14_33_06 Name="Start Time: Mon Jun 10 14:31:04 2013" Error="" /> <date_10.06.2013_14_33_06 Name="Executing (Buffer): Buffer "Feature Set" C:\Users\1\AppData\Local\Temp\arcgisruntime_6260\clipfeatures\jobs\_\j093970f38300414a902fc9e7f4dc18e0\scratch\scratch.gdb\Polyline_Buffer "100 Kilometers" FULL ROUND NONE #" Error="" /> <date_10.06.2013_14_33_06 Name="Start Time: Mon Jun 10 14:31:04 2013" Error="" /> <date_10.06.2013_14_33_06 Name="WARNING 000117: Warning empty output generated." Error="" /> <date_10.06.2013_14_33_06 Name="Succeeded at Mon Jun 10 14:31:04 2013 (Elapsed Time: 0,00 seconds)" Error="" /> <date_10.06.2013_14_33_06 Name="Executing (Clip): Clip ClipFeatures\Counties C:\Users\1\AppData\Local\Temp\arcgisruntime_6260\clipfeatures\jobs\_\j093970f38300414a902fc9e7f4dc18e0\scratch\scratch.gdb\Polyline_Buffer C:\Users\1\AppData\Local\Temp\arcgisruntime_6260\clipfeatures\jobs\_\j093970f38300414a902fc9e7f4dc18e0\scratch\scratch.gdb\Polyline_Buffer_Clip #" Error="" /> <date_10.06.2013_14_33_06 Name="Start Time: Mon Jun 10 14:31:04 2013" Error="" /> <date_10.06.2013_14_33_06 Name="WARNING 000117: Warning empty output generated." Error="" /> <date_10.06.2013_14_33_06 Name="Succeeded at Mon Jun 10 14:31:05 2013 (Elapsed Time: 1,00 seconds)" Error="" /> <date_10.06.2013_14_33_06 Name="Executing (Select Data): SelectData C:\Users\1\AppData\Local\Temp\arcgisruntime_6260\clipfeatures\jobs\_\j093970f38300414a902fc9e7f4dc18e0\scratch\scratch.gdb\Polyline_Buffer_Clip #" Error="" /> <date_10.06.2013_14_33_06 Name="Start Time: Mon Jun 10 14:31:05 2013" Error="" /> <date_10.06.2013_14_33_06 Name="Succeeded at Mon Jun 10 14:31:05 2013 (Elapsed Time: 0,00 seconds)" Error="" /> <date_10.06.2013_14_33_06 Name="Succeeded at Mon Jun 10 14:31:05 2013 (Elapsed Time: 1,00 seconds)" Error="" /> <date_10.06.2013_14_33_06 Name="Succeeded at Mon Jun 10 14:31:05 2013 (Elapsed Time: 2,00 seconds)" Error="" /> <date_10.06.2013_14_33_06 Name="Succeeded at Mon Jun 10 14:31:05 2013 (Elapsed Time: 2,00 seconds)" Error="" /> </Log>
Solved! Go to Solution.
Error executing tool.: ERROR 000800: The value is not a member of Polyline_Buffer_Clip | FirstLayer | SecondLayer. The value does not exist.
parameters.Add(new GPFeatureRecordSetLayer("Input", CountiesFeatures));something like that
Failed to create service clipfeature GPServer. Worker process 'clipfeature_host' exited while attempting to service request (attempt 1 of 1): endpoint='admin' headers={} params={filePath=f:\documents\visual studio 2012\projects\geoprocessing\geoprocessing\gpk\clipfeature.gpk, jobDir=C:\Users\1\AppData\Local\Temp\arcgisruntime_5052\clipfeature\jobs, maxRecords=1000, name=clipfeature, outputDir=C:\Users\1\AppData\Local\Temp\arcgisruntime_5052\clipfeature, type=GPServer, virtualDir=http://127.0.0.1:50000/ph8z9n/outputdir/clipfeature} res='create' post=0 Crash dump path=C:\Users\1\AppData\Local\Temp\ArcGISRuntimeErrorReports\arcgisruntime_10.1.1.3298_service_20130614_145854.dmp Error code: 500
