The connection property set was missing a required property or the property value was unrecognized. Cannot connect to database because the database client software failed to load. Be sure the database client software is installed and configured correctly.
Have you put the path to the 64-bit client libraries before the path to the 32-bit libraries in the PATH environment variable?
