I cant see services if i connect to ArcGis Server using ArcCatalog 10.1 from web. But all works fine if i connect directly to ArcGis Server using ArcCatalog 10.1.
What operating system? In 10.1 you don't need a reverse proxy, just use web adaptor. But if you already have one in place and need to use, then see the following:
