I have 2 MapControls in my program, both are showing the same layers from the same MPK.
When the user draws a point in map A, then map B is not showing that point, until i move the map with the mouse.
I set DisableClientCaching to true for that layer, and also called Refresh() and Update() methods - but nothing seems to be really refreshing that layer.
I even tryed to change the extent and zoom back and forth in the code behind, to make that point appear on the map - but still nothing worked.
Any suggestions?
Team Igal
