A simple "if not" statement would work, try posting the code you are running for more detailed help.
import arcpy import os from arcpy import env # Location where the images will be copied to: arcpy.env.workspace = r'X:\Archive\1930_1949\MO\JP2_Zone15' with open(r'X:\Archive\Python_Scripts\UTM_15.txt', 'r') as f: prj = f.readlines()[0] outPath = arcpy.env.workspace listFiles = open(r'X:\Archive\1930_1949\MO\Index\List_Files_Zone15.csv', 'r') for inputRasters in listFiles.readlines(): inputFilenames = os.path.splitext(os.path.basename(inputRasters))[0] print inputFilenames print inputRasters outPut = os.path.join(outPath,inputFilenames + ".jp2") print outPut print '' arcpy.ProjectRaster_management(inputRasters, outPut, prj)
if (os.path.exists('outPut')): os.remove('outPut')
import arcpy import os from arcpy import env # Location where the images will be copied to: arcpy.env.workspace = r'X:\Archive\1930_1949\MO\JP2_Zone15' with open(r'X:\Archive\Python_Scripts\UTM_15.txt', 'r') as f: prj = f.readlines()[0] outPath = arcpy.env.workspace listFiles = open(r'X:\Archive\1930_1949\MO\Index\List_Files_Zone15.csv', 'r') Fname_old = "" cnt = 0 for inputRasters in listFiles.readlines(): inputFilenames = os.path.splitext(os.path.basename(inputRasters))[0] if Fname_old != inputFilenames: cnt = 0 print inputFilenames print inputRasters outPut = os.path.join(outPath,inputFilenames + ".jp2") print outPut print '' if arcpy.Exists(outPut): ### This will delete the file if it already exists arcpy.Delete_management(outPut) ### However, if it is in your list, I suspect that you want it regardless of filename already exists if arcpy.Exists(outPut): cnt += 1 Fname_old = inputFilenames outPut = os.path.join(outPath,inputFilenames + "_" + str(cnt) + ".jp2") ### This would append an _# (1,2,3, etc) to the of the filename and project/save it anyway arcpy.ProjectRaster_management(inputRasters, outPut, prj)
MyList = [] outPath = r'X:\Archive\1930_1949\MO\JP2_Zone15\' for inputRasters in listFiles.readlines(): inputFilenames = os.path.splitext(os.path.basename(inputRasters))[0] if inputFilenames not in MyList: MyList.append(inputFilenames) else: continue for filename in MyList: outPut = os.path.join(outPath,filename + ".jp2") arcpy.ProjectRaster_management(filename, outPut, prj) Of course, if you really don't want it to do anything when the filenames are duplicates, you can read your filelist into a python list, then make a set of it. Sets will remove any duplicates and the resultant set will have unique values only. for inputRasters in listFiles.readlines(): inputFilenames = os.path.splitext(os.path.basename(inputRasters))[0] MyList.append(inputFilenames) MySet = set(MyList) for rasts in MySet: outPut = os.path.join(outPath,rasts + ".jp2") arcpy.ProjectRaster_management(rasts, outPut, prj)
this worked for me, see the if/else statements
# Import arcpy module
import arcpy
from arcpy.sa import*
import os
import sys
# Local variables:
env.workspace = "R:\\moriver\\Aerials\\Aerials1930\\Images\\"
outs = "E:\\1930_IMG\\"
rasterList =[]
count = 0
for dirname, dirnames, filenames in os.walk ('R:\\moriver\\Aerials\\Aerials1930\\Images\\'):
for subdirname in dirnames:
print os.path.join(dirname, subdirname)
env.workspace = os.path.join(dirname, subdirname)
rasters = arcpy.ListRasters()
for inRaster in rasters:
Name = inRaster[:-4]
print Name
Name = inRaster
outs = "E:\1930_IMG" + Name
if arcpy.Exists (outs):
print "it already exists"
else:
outras = "E:\\1930_IMG\\"
arcpy.RasterToOtherFormat_conversion (inRaster, outras, "IMAGINE Image")
print "Success"
