idolevi
Creating Symbol from JSON issue
Discussion created by idolevi on May 23, 2013
I'm using JS API 3.4, I get a JS exception when I create renderer from string that I parsed to JSON.
I succeed to isolate the problem, and discovered that the problem is actually in the symbol that was created from JSON.
I took an example from the API Reference and succeed to reproduce the problem, this is the code snippet i took from the API Reference:
var symbol =  new esri.symbol.PictureMarkerSymbol({
  "url":"graphics/redArrow2.png",
  "height":20,
  "width":20,
  "type":"esriPMS"
until here all's good, but now I want to convert it back again to JSON (when I do this, I get the same exception as I get from the renderer):
symbol.toJson();
UPDATE:
The JS code in init.js try to use private members from this.constructor, but it's empty if creating the symbol from JSON so I get exception.
If the symbol is created by passing all parameters and not by JSON, this.constructor contains the private members.
Any Idea?
Outcomes
