<Msg time='2010-06-21T17:41:36' type='ERROR' code='100005' target='California.MapServer' methodName='MapServer.GetTileCacheInfo' machine='purehate' process='1868' thread='3548' elapsed='0.00012'>Method failed.HRESULT = 0x80004005 : Unspecified error .</Msg>
<ServerObjectConfiguration>
<Description>Map Description</Description>
<Properties>
<FilePath>D:\Maps\California.mxd</FilePath>
<OutputDir>\\PUREHATE\arcgisoutput</OutputDir>
<VirtualOutputDir>http://purehate/arcgisoutput</VirtualOutputDir>
<MaxImageHeight>2048</MaxImageHeight>
<MaxRecordCount>500</MaxRecordCount>
<MaxBufferCount>100</MaxBufferCount>
<SupportedImageReturnTypes>URL</SupportedImageReturnTypes>
<IsCached>false</IsCached>
<CacheOnDemand>false</CacheOnDemand>
<IgnoreCache>false</IgnoreCache>
<ClientCachingAllowed>true</ClientCachingAllowed>
<CacheDir>c:\arcgisserver\arcgiscache\California</CacheDir>
<SOMCacheDir>c:\arcgisserver\arcgiscache</SOMCacheDir>
</Properties>
<Extension>
<TypeName>KmlServer</TypeName>
<Enabled>false</Enabled>
<Properties>
<ImageSize>1024</ImageSize>
<Composite>true</Composite>
<Dpi>96</Dpi>
<UseNetworkLinkControlTag>false</UseNetworkLinkControlTag>
<MinRefreshPeriod>30</MinRefreshPeriod>
<LinkDescription></LinkDescription>
<LinkName></LinkName>
<Message></Message>
<UseDefaultSnippets>false</UseDefaultSnippets>
<EndPointURL>http://purehate/ArcGIS/services/Californiasdf/MapServer</EndPointURL>
</Properties>
<Info>
<WebEnabled>true</WebEnabled>
<WebCapabilities>SingleImage,SeparateImages,Vectors</WebCapabilities>
</Info>
</Extension>
<Extension>
<TypeName>MobileServer</TypeName>
<Properties>
</Properties>
<Info>
</Info>
</Extension>
<Extension>
<TypeName>NAServer</TypeName>
<Properties>
</Properties>
<Info>
</Info>
</Extension>
<Extension>
<TypeName>WCSServer</TypeName>
<Properties>
</Properties>
<Info>
</Info>
</Extension>
<Extension>
<TypeName>WFSServer</TypeName>
<Properties>
</Properties>
<Info>
</Info>
</Extension>
<Extension>
<TypeName>WMSServer</TypeName>
<Properties>
</Properties>
<Info>
</Info>
</Extension>
<Recycling>
<Start>00:00</Start>
<Interval>86400</Interval>
</Recycling>
<Info>
<WebCapabilities>Map,Query,Data</WebCapabilities>
</Info>
<IsPooled>true</IsPooled>
<MinInstances>1</MinInstances>
<MaxInstances>2</MaxInstances>
<InstancesPerContainer>1</InstancesPerContainer>
<WaitTimeout>60</WaitTimeout>
<IdleTimeout>-1</IdleTimeout>
<UsageTimeout>600</UsageTimeout>
<CleanupTimeout>30</CleanupTimeout>
<StartupTimeout>300</StartupTimeout>
<Isolation>high</Isolation>
<StartupType>automatic</StartupType>
</ServerObjectConfiguration>
in fact the service is not cached..its a dynamic map service,,
i forgot mentioning something very important, im publishing map on the fly through a webserivce, the map is published with no problem, shows in ADF map control, but rest is causing problem, is there anything im missing ??
if i publish map through Arccatalog or Server Manager everything works fine.
