Map Packages instead of Tile Packages
487
05-17-2013 07:28 AM
shaileshgavathe
Occasional Contributor II
I am new to ArcGIS Runtime SDK for WPF.
Can we use Map Packages directly using Runtime SDK? If yes, Is there any documentation that is available for reference please?
Thanks and Regards,
Shay ~
AnttiKajanus1
Occasional Contributor III
Here is concepts in WPF runtime conserning MapPackages: http://resources.arcgis.com/en/help/runtime-wpf/concepts/index.html#/About_map_packages/017000000059...
You can find examples from ArcGIS Runtime SDK for WPF samples application that you get when installing the SDK. There all examples that doesn't have postfix Online uses local layers (tile or map package).
If you have more specific questions, then we can answer more detailed.
BrianLocke
http://video.esri.com/watch/2321/implementng-analysis_comma_-editing_comma_-and-offline-applications...
Great Session Some very key things are pointed out that I have yet to discover within the API or Concept documentation, these guys are definately willing to answer any questions also
