Hi Ron,
Could you post your XAML/C#?
The navigation sample for the SDK has the following XAML:
<esri:Map x:Name="MyMap" Extent="-15000000,2000000,-7000000,8000000" WrapAround="True">
<esri:ArcGISLocalTiledLayer ID="myBaseMap" Path="..\\Data\\TPKs\\Topographic.tpk"/>
</esri:Map>
<esri:Navigation Margin="5" HorizontalAlignment="Left" VerticalAlignment="Bottom"
Map="{Binding ElementName=MyMap}" />
And no extra C# is required in the sample.
Here is the XAML: <esri:Navigation Height="140"
Background="SteelBlue"
Margin="0,0,605,344"
Name="navigation"
VerticalAlignment="Top"
Width="176"
Foreground="SteelBlue"
PanFactor="0.25"
IsManipulationEnabled="False"
Opacity="1"
<esri:Navigation.Map>
<esri:Map MinimumResolution="0.0000000000001" IsLogoVisible="False" WrapAround="True" />
</esri:Navigation.Map>
</esri:Navigation>
After some more testing it appears that the problem is because the <esri:Navigation.Map> is being set. Once I remove those four lines of XAML it works as your example shows.
