# Import arcpy module import arcpy, os from arcpy import env from arcpy.sa import * # Check out any necessary licenses arcpy.CheckOutExtension("spatial") # Input data source arcpy.env.workspace = "C:/py/07" arcpy.env.scratchWorkspace = "C:/py/07" arcpy.env.overwriteOutput = True ZoneData = "C:/py/FISHNET_4k_FeatureToPolygon.shp" # Output File OutputFolder = "C:/py/zonal" # Loop through a list of files in the workspace RasterFiles = arcpy.ListRasters() print RasterFiles print " " # Local variables: for filename in RasterFiles: print "Processing: {0}".format(filename) input_dir = arcpy.env.workspace inRaster1 = "C:/py/07/lai_0907_m" outRaster1 = os.path.join(OutputFolder,"z4_" + filename) # Process: Zonal Statistics saveRaster = arcpy.sa.ZonalStatistics(ZoneData, "ID", inRaster1, "MEAN", "DATA") saveRaster.save(outRaster1) print "done"
Solved! Go to Solution.
for filename in RasterFiles: print "Processing: {0}".format(filename) #input_dir = arcpy.env.workspace #inRaster1 = "C:/py/07/lai_0907_m" outRaster1 = os.path.join(OutputFolder,"z4_" + filename) # Process: Zonal Statistics #saveRaster = arcpy.sa.ZonalStatistics(ZoneData, "ID", inRaster1, "MEAN", "DATA") saveRaster = arcpy.sa.ZonalStatistics(ZoneData, "ID", filename, "MEAN", "DATA") saveRaster.save(outRaster1)
