I am creating a 3D view of a trail and I am having problems with generating trees in city engine. Right now I have a point shp file on my terrain of all the trees within that area. The only post I have found on this subject was on this site(Creation of 3D Trees) however that code block is not working for me. I Have the same obj. file from the philly example in my assets folder and then I select the point and assign the rule to that point an hit generate but nothing happens. No errors in the log either. Am I forgetting something? I Am also curious about Sketchup, I downloaded a tree from there library and exported it as a dae file. My question again come when trying to generate the tree. The code I am using is this tree --> i( "models/PineTree.dae" ) again am I missing something?
ahhh.... Not a dumb question at all. That was my problem Thank you. While I am on the Subject I do have a question about the black lines that are outlining the tree, how do i make them go away?[ATTACH=CONFIG]24290[/ATTACH]
