ArcSDE 10.1 service, esri_sde, creation failed
2283
05-07-2013 10:21 AM
xiannianchen
Hi, friends,
I am doing MS SQL Server (2012 version) based ArcSDE (10.1). I followed the installation guide to do create and start the service. But when I started the service, it is always failed. No matter what I do, I always get the error message of "The ArcSDE Service (esri_sde) service on Local Computer started and then stopped. Some services stop automatically if they are not in use by other services or programs".
Since I am following the installation guide and I want to create the service on the local server machine, I want to ask experts questions based on the steps.
1. for creating the service, I use the default service name, which is esri_sde. My machine name is TEST1, and the SQL Server instance name is: MSSQLSERVER.
In the sample command line: sdeservice -o create -d SQLSERVER,MYSERVER\SSINSTANCE -i sdesvc -p keepout
For the d parameter, if I use TEST1\MSSQLSERVER, it gives me the error message: Database service MSSQL$MSSQLSERVER does not exist. Use option -n to exclude MSSQL$MSSQLSERVER from ArcSDE dependent service..
If I use only machine name, it works.
For me, the working command line is: sdeservice -o create -d SQLSERVER,CATEVAC2 -p keepout.
2. for register operation of ADMIN_DATABASE , the sample command is:
sdeservice -o register -d SQLSERVER,MYSERVER\SSINSTANCE -r ADMIN_DATABASE -v mygdb
In my case, I changed MYSERVER\SSINSTANCE to TEST1.
My questions are: what is ADMIN_DATABASE?
How to set it? There is no database mygdb in the instance.
Should this database pre-exist? I created a sde database by using the Database Management Studio, and I changed "mygdb" to "sde".
So, in my case, the register database opertion command line is:
sdeservice -o register -d SQLSERVER,TEST1 -r ADMIN_DATABASE -v sde
3. for register operation of SDE_DBA_USER, the sample command is:
sdeservice -o register -d SQLSERVER,MYSERVER\SSINSTANCE -r SDE_DBA_USER -v "localhost\network service" -i sdesvc
I changed MYSERVER\SSINSTANCE to TEST1 and removed -i sdesvc since I want to use the default service name. So, my working verion of command line is:
sdeservice -o modify -d SQLSERVER,TEST1 -r SDE_DBA_USER -v "localhost\network service"
In my case, three commands were executed successfully. But when I tried to start up the esri_sde, I got error messages as I mentioned before.
Any else setting that I left out?
Thanks for any help.
-Mike
BubbaHey
Occasional Contributor III
AbhijitSarkar
Here are the steps if it's sde schema geodatabase:
i) Write the unique ArcSDE service name and port number (example: esri_sde   5151/tcp) in SDEHOME/services.sde and windows service file (located at C:\Windows\System32\drivers\etc\services)
ii) Make sure the SDEHOME is set (echo %SDEHOME%) correctly. if not "set SDEHOME= 'correct SDEHOME path'"
iii) execute the following command: sdeservice -o create -d SQLSERVER,SQLSERVERINSTANCE -p <password> -i 5151
iv) then execute "sdeservice -o register -d SQLSERVER, SQLSERVERINSTANCE -r ADMIN_DATABASE -v <Database Name> -i 5151"
v) Try starting the service from windows service panel.
ADMIN_DATABASE would write on the windows registry regarding the database value for that ArcSDE service. That's how you would know that 5151 service is running/registered for which database.
I hope this helps. Let us know how it goes.
Thanks..
xiannianchen
Thanks, first.
But, basically, that's about the same as the installation instruction, except the service name is 5151 other than the default name of esri_sde.
I did try your suggestion. The service can't be started. The same error message appeared again.
Any other suggestions?
Mike
Thanks..
AbhijitSarkar
Can you post the following: sdeservice -o list -i 5151 ?
