I miss the Context server, ArcObjects in 9.3... There are Zero examples of Feature Service SOAP.Delete was easy...Add is a different story...I am talking about this:http://resources.arcgis.com/en/help/soap/10.1/index.html#/Add/01vp0000007v000000/I have no idea how to get this to work...Ideas?I know if this was a FEATURE, i would then use ESRI.ArcGIS.SOAP.GraphicFeature(), but this is a record for a table that is accessible through a feature service.I am able to get a PropertySet.propertyarray but what to do with it... to get it to a pDataObjects. Dim CatalogServiceProxy As New ESRI.ArcGIS.SOAP.ServiceCatalogProxy
CatalogServiceProxy.Url = CatalogServiceURL
'If CatalogServiceProxy.RequiresTokens() = True Then
' Dim ArcToken As New ArcServerToken(CatalogServiceURL, UserID, Password)
' Token = ArcToken.GetToken()
'End If
Dim FeatureServiceProxy As New ESRI.ArcGIS.SOAP.FeatureServerProxy
'FeatureServiceProxy.Url = FeatureServiceURL + "token=" + myToken
Dim inputfields As ESRI.ArcGIS.SOAP.PropertySetProperty() = New ESRI.ArcGIS.SOAP.PropertySetProperty(2) {} ' There are TWO Fields / values
Dim pPropertySet As New ESRI.ArcGIS.SOAP.PropertySet
Dim pDataObjects As New ESRI.ArcGIS.SOAP.DataObjects
Dim pPropertySetPropertyLINCNumber As New ESRI.ArcGIS.SOAP.PropertySetProperty
Dim pPropertySetPropertyTrackStatusID As New ESRI.ArcGIS.SOAP.PropertySetProperty
pPropertySetPropertyTrackStatusID.Key = adofields.name
pPropertySetPropertyTrackStatusID.Value = "Some value"
inputfields.SetValue(pPropertySetPropertyTrackStatusID, 0)
inputfields.SetValue(pPropertySetPropertyLINCNumber, 1)
pPropertySet.PropertyArray = inputfields
******* WHAT TO PUT HERE *******
'Store the array, ignore the result at this time.
Dim Result As ESRI.ArcGIS.SOAP.EditResult() = FeatureServiceProxy.Add(1, pDataObjects, Nothing, True, False)
