tkellymc
Map Re-Size Scaling
Discussion created by tkellymc on May 2, 2013
Latest reply on Jul 8, 2013 by jakubsisak
Good Afternoon Everyone.
Currently I am converting a large amount of maps from 8.5 by 11 (normal size) to 11 by 17 large size. Whenever I change the printer settings to the larger size the original map stays the same size. Unfortunately this makes re-sizing and reformatting an arduous chore as each element and graphic needs to be re-sized, re-scaled and re-shaped. Is there any way to change the size (or print settings of a document in ArcMap) and have the current existing map products adapt to this new size automatically instead of manually changing each element?
Thanks for your help
Outcomes
