I had installed server on new computer (Windows 7) with sp1 and every thing was fine. Then I tryed to install SDE on 2012 MS SQL Server. And this worked ok. Then our company needs MS SQL 2008, and we have a lot problems with this. So after installing and unninstaling programms and features it started to work, but ArcGis server dont work now. Browser: Error 324 (net::ERR_EMPTY_RESPONSE) Windows services: ArcGIS server working
try to reinstall, it is not working. Errors the same. Fiddler says that there areno server response. Can someone help with this weird problem? My system: IIS8, Windows7 sp1 x64, MSSQL 2012, Visual Studio 2012, ArcGis 10.1, ArcGis for WPF, ArcGis SDE, ArcGis Server.
Have you read my messages? I had attached files before.
I solved problem with my colleagues. All you need to change IP port from 6080 to another. You need to do it here ArcGIS\Server\framework\runtime\tomcat\conf\server.xml and here ArcGIS\Server\framework\etc\machine-config.xml.
Are you using Chrome? That sounds like a Chrome error not ArcGIS. Try Internet Explorer. IF same error, try running ArcGIS > ArcGIS 10.1 Server > Configure ArcGIS Server Account
I try to re-install ArcGIS, re-config ArcGISserver account and restart ArcGIS services. Its all have no errors. But did not help me. Strange thing that C:\arcgisserver\config-store, directories and logs is empty
