Jonathan,
I am trying to publish 30 map documents, which use the same file geodatabase. I have registered (and validated) with the server (10.1) my local file directory that contains my file geodatabase. But, every time I try to publish another map document (from the 30 map documents), I get the warning that the data source is not registered with the server! And, when I right-click (in Analyze window) to see if the data source is registered, it shows as registered, and validated. What am I not doing that I should be?! I followed ArcGIS 10.1 Help. I appreciate your help.
Mehrshad
