Unregistered data copied to ArcGIS Server with service
1703
04-23-2013 01:18 PM
SachinChand
When publishing a map service, if the .mxd contains unregistered (w/ArcGIS Server) data, the data is copied to ArcGIS Server.  My questions are,
1. What is the location where the data is copied?  Is it \config-store\data ?
2. Is the data deleted when the service is deleted?  If not, how does one go about deleting it?
Thank you
DerekLaw
Esri Esteemed Contributor
Hi Sachin,
A1. The location of the copied data is:
C:\arcgisserver\directories\arcgissystem\arcgisinput
Note that the path above is for a single machine installation with the default install paths.
A2. Yes, when you delete the service, its associated data will also be deleted.
Hope this helps,
DerekLaw
Hi Sachin,
Hope this helps,
SachinChand
Thanks Derek!
