What is the correct way to overload the map object so that you can take advantage of new way to create a map? The new way allows you to just set the basemap property. (Example below). Is there a way to set that to point to a Portal basemap instead of requiring access to arcgisonline?
function init() {
var map = new esri.Map("map",{
basemap:"topo",
center:[-122.45,37.75], //long, lat
zoom:13,
sliderStyle:"small"
