jpedder
MakeRasterLayer, doesn't
Discussion created by jpedder on Apr 13, 2013
Latest reply on Apr 13, 2013 by startch0
From my previous post having trouble writing a raster from a viewshed. I have the viewshed raster writing correctly to my scratch DB, however as much as i try I can't get MakeRasterLayer_management to create a raster file either in the dataframe or to disk.
If I run this line of code from Python geoprocessing inside ArcMap the layer add correctly
ping_layer = 'path to layer in the scratch gdb'
arcpy.MakeRasterLayer_management(Final_Viewshed,ping_layer,rQuery)
running from a standalone script is does nothing. Here's a code snippet so you can see what's going on. Obviously lots of messages etc for me to see what's going on
# Set enviroment, frames and layers
arcpy.env.workspace
arcpy.env.scratchWorkspace
scratchdb = arcpy.env.scratchGDB
scratchfdr = arcpy.env.scratchFolder
if arcpy.CheckOutExtension('Spatial'):
    if arcpy.GetCount_management(inObserverFeatures) != 0:
        arcpy.AddMessage('Ping count is {0}'.format(arcpy.GetCount_management(inObserverFeatures)))
        outViewshed = Viewshed(clippedraster, inObserverFeatures, zFactor, useEarthCurvature, refractivityCoefficient)
        Final_Viewshed ='{0}\Final_Viewshed_{1}'.format(scratchdb,timestamp)
        outViewshed.save(Final_Viewshed)
        rQuery = '{0} > 0'.format(arcpy.AddFieldDelimiters(outViewshed.name.title(),"Value"))
        arcpy.AddMessage('Final_Viewshed_{0}'.format(Final_Viewshed))
        if Final_Viewshed:
            arcpy.AddMessage('Found {0}'.format(Final_Viewshed))
            ping_layer = '{0}\PingLayer_{1}.lyr'.format(scratchfdr,timestamp)
            arcpy.AddMessage('ping layer = {0}'.format(ping_layer))
        else:
            arcpy.AddMessage('Not there')
Everything appears to work properly other than the MakeRasterLayer
Pretty frustrated at this point, I've tried all I can.
Outcomes
