aafgilbert01
<esri:FillSymbol x:Key="ResultsFillSymbol">
Discussion created by aafgilbert01 on Apr 11, 2013
Latest reply on May 1, 2013 by MBranscomb-esristaff
I have looked at the WFP SDK example where a query to a layer shows the selected graphic and at the same time you see the graphic that are selected in the attribute table. That example works with a polygone feature layer. In the example the "ResultsFillSymbol" is used to define how the poygone will appear when "Normal", "Selected", "mouse move". I would like to use that example and make it work for Marker and Lines. Is it possible to use a more generic FillSymbol to work with the 3 types of features and if so, do you have an example.
Regards
François Gilbert
Outcomes
