warning : div proprietary attribute "data dojo-type" - Aptana 3
2585
6
04-09-2013 12:16 PM
ionarawilson1
Occasional Contributor III
I am  using Aptana 3 but I am frustrated with the lack of code assist it has. Also I copied a sample but I am getting warnings
Here is the sample
http://developers.arcgis.com/en/javascript/jssamples/map_imagery.html
And the warnings I get for the two divs in the code below is:
 <body class="claro">     <div data-dojo-type="dijit.layout.BorderContainer"          data-dojo-props="design:'headline', gutters:false"          style="width: 100%; height: 100%; margin: 0;">              <div id="map"             data-dojo-type="dijit.layout.ContentPane"             data-dojo-props="region:'center'"             style="overflow:hidden;">       </div>      </div>
Does anybody know why I am getting these warnings? And also, how can I get good intellisense in Aptana 3?
Thanks!!!
KenBuja
MVP Esteemed Contributor
Have you downloaded the code assist plugin from here? Hopefully the 3.4 version will be available soon.
KenBuja
ionarawilson1
Thank you for the link Ken. Where can I find samples for the 3.3 Api? I can only find for the 3.4 api. And do you know why I am getting those warnings I mentioned ? Thanks
KenBuja
You can download all the samples in the 3.3 SDK available here. Unfortunately, I'm a new convert to JavaScript, so I can't help you with your dojo warning question.
ionarawilson1
Thank you for the link Ken. I followed the steps below and it resolved the problem.
In Preferences > Aptana Studio > Validation > HTML Tidy Validator > Attributes >> Proprietary attributes --> ignore
JeffJacobson
Any attribute starting with "data-" is valid under HTML5, so you shouldn't have had to disable detection of proprietary attributes.  Does your HTML document include the HTML5 doctype?
ionarawilson1
Jeff, Yes, here is the code
<!DOCTYPE html>
<html>
  <head>
  <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9">
    <title>JavaScript Seminar</title>
<script type="text/javascript">djConfig = { parseOnLoad:true }</script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=1.4"></script>
    <style type="text/css">
      @import "http://serverapi.arcgisonline.com/jsapi/arcgis/1.4/js/dojo/dijit/themes/tundra/tundra.css";
    </style>
        //This demo application is intended for education purposes only and associated with the
        //ESRI JavaScript API 1/2 day seminars presented in the fall of 2008.
        //Register for seminars at:
        // http://www.esri.com/events/seminars/arcgis93_server/index.html
        //All the services used in the following demonstrations rely on ESRI sample servers.
        //The services running on the sample servers may change in the future;
        //thus, you should not rely on the services in your own applications.
        //The sample server services are being utilized in this seminar for demonstration purposes only.
        //As the demonstrations rely on the sample servers, the content of these demos will only be valid as long as the services on the sample servers continue to run.
      dojo.require("esri.map");
      dojo.require("dijit.TitlePane"); //For Floating panel
      dojo.require("dijit.form.TextBox");
      dojo.require("dijit.Dialog");
      dojo.require("dojo.data.ItemFileWriteStore");
      dojo.require("dijit.dijit"); // optimize: load dijit layer
      var map; //represents esri.map
      var imagery; //arcgisonline imagery
      var streetMap; //arcgisonline streetmap data
      var portlandService; //Portland Data from sample server
      var dynamicMapServiceLayer; //Census Block data
      function init() {
        var startExtent = new esri.geometry.Extent({ xmin: -123.6, ymin: 44.873, xmax: -121.645, ymax: 45.793, spatialReference: new esri.SpatialReference({wkid: 4326})});
         map = new esri.Map("map", { extent:startExtent } );
        imagery = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_Imagery_World_2D/MapServer");
        map.addLayer(imagery);
        streetMap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer", {id:"streetMap"});
        map.addLayer(streetMap);
        streetMap.hide();
         portlandService = new esri.layers.ArcGISTiledMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Portland/Portland_ESRI_LandBase_AGO/MapServer", {id:"portlandService"});
         portlandService.setOpacity(0.75);
         map.addLayer(portlandService);
         //For Dynamic Layer when floating panel opens
        var a = dijit.byId('horizontalSlider');
       onClickHandle = dojo.connect(a.sliderHandle, 'onmouseup', function(e) { updatemap(dojo.byId('popDens').value); });
       var b = dijit.byId('CensusTitle');
       onToggleHandle = dojo.connect(b, 'toggle', function(e) { if (b.open) { addDynamic(dojo.byId('popDens').value); } else { dynamicMapServiceLayer.hide();}});
      function TurnOffStreetMap() {
          streetMap.hide();
          imagery.show();
      function TurnOffImagery() {
          imagery.hide();
          streetMap.show();
      function addDynamic(inVal) {
         dynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer");
        dynamicMapServiceLayer.setVisibleLayers([1]);
        var layerDefinitions = [];
        layerDefinitions[1] = "POP07_SQMI > " + inVal;
        dynamicMapServiceLayer.setLayerDefinitions(layerDefinitions);
         map.addLayer(dynamicMapServiceLayer);
      function updatemap(inVal) {
      dojo.addOnLoad(init);
    </script>
  </head>
   <body class="tundra">
     <table>
      <tbody>
        <tr>
          <td>
            <div style="position:relative;">
              <div id="map" style="width:1100px; height:600px; border:1px solid #000;">
              </div>
              <div style="position:absolute; right:25px; top:10px; z-Index:999;">
                        <button id= "Button1"  onClick="TurnOffStreetMap()">Imagery</button>
                        <button id="button2" onClick="TurnOffImagery()">Street Map</button>
              </div>
            </div>
          </td>
          <td valign="top">
          </td>
        </tr>
      </tbody>
    </table>
  </body>
I get a warning "button proprietary attribute "on Click" in these:
              </div>
