charmalee
Export Web Map GP Task -does not refresh
Discussion created by charmalee on Apr 8, 2013
Latest reply on Oct 24, 2013 by ahoque-esristaff
I have created a custom print GP task: http://maps.peterborough.ca/arcgis/rest/services/ExternalSiteLayouts/ExportWebMap/GPServer
The working task can be found here: http://maps.peterborough.ca/emaps/
The print itself works but a problem I have run into in Chrome and IE is that after I print once and then create another print, the initial job does not refresh and therefore the old job shows up. If I delete browsing history that sometime helps but not always.
Is there a way to adjust the settings on the GP task to make sure the print job refreshes each time I print?
Charmalee
Outcomes
