PointClass p1 = new PointClass(); PointClass p2 = new PointClass(); // Add data to points for test p1.PutCoords(34.481560, 41.515391); p2.PutCoords(34.702832, 41.795668); ILine lineForAngle = new Line(); IMeasurementTool measurementTool = new MeasurementToolClass(); measurementTool.ConstructByPoints(p1, p2); // Here we calculate distance between two points: (p1, p2) double distance = measurementTool.Distance; GeometryEnvironment geoEnv = new GeometryEnvironment(); IConstructAngle angleCalculator = (IConstructAngle)geoEnv; lineForAngle.PutCoords(p1, p2); // Here we calculate angle of line between (p1, p2) and the positive x-axis double angle = angleCalculator.ConstructLine(lineForAngle); // Convert radian to degree angle *= 180 / Math.PI; // = 51.709836807757121 Degree // Convert angle to azimuth (still degree) angle = 90 - angle; // = 38.290163192242879 // Here I give first point (p1), azimuth and distance to get p2 measurementTool.ConstructByPointDistAngle(p1, distance, angle); geoEnv = new GeometryEnvironment(); angleCalculator = (IConstructAngle)geoEnv; // I put p1 and result point of measurementTool which is a point lineForAngle.PutCoords(p1, measurementTool.ToPoint); // Now I have calculate angle between p1 and result of measurementTool angle = angleCalculator.ConstructLine(lineForAngle); angle *= 180 / Math.PI; // = 43.443603752680005 // first angle - result angle: // 51.709836807757121 - 43.443603752680005 = 8.266233055077116
Dear All,
I have 2 points which creates a line. I want to get angle of line and then draw another line with +30 degree. I can do it but I always get 7-10 degree more than actual angle.
I get distance between 2 points using IMeasurementTool.ConstructByPoints, then I get angle using IConstructAngle.ConstructLine. Here I have angle and distance between 2 points. Now, I'll give ConstructByPointDistAngle first point, distance and angle to get second point. Now I calculate angle between first point and result point of ConstructByPointDistAngle but I get angle with 8.266233055077116 degree difference.
I think I'm not convert degree to azimuth correctly. Any idea?
FYI: azimuth is degrees clockwise from north
Here is my working code with comment and Debug results. Red texts are debug results.
Hi!
To the point of your problem.
You use the intricate algorithm. I think it's easier to use IConstructPoint.ConstructDeflection method with the negative value of the angle (in radians) and the necessary distance.
Thank you a-subbotin for introducing me IConstructPoint.
Well, I used it based on ArcObjects' Help but result point was not correct. I used IConstructPoint.ConstructAngleDistance but result X,Y is so large numbers! My X,Ys are longtitude,latitude and distance is meter. Do you know ConstructAngleDistance's unit?
angle = 90 - angle;
to a-subbotin:
Sorry, I didn't get what to do. How can I make ConstructAngleDistance function to use longtitude, latitude and meter? Can you please explain more or give me example code?
Thank you
to Wayne_Whitley:
Thank you for your reply.
Unfortunately I can't use toolboxes. I should implement it using .NET code. If you could help me on ConstructAngleDistance, that would be great.
Actually I subtract 90 degrees; as you see:angle = 90 - angle;
but I don't get correct angle.
