How do I setup a NSDictionary this this JSON?
3042
06-14-2010 01:01 PM
ChanceYohman
"spatialReference": {"wkid" : 4326},
"candidates" : [
  "address" : "1 MASON ST",
  "location" : { "x" : -122.408951, "y" : 37.783206 },
  "score" : 75,
  "attributes" : {"StreetName" : "MASON", "StreetType" : "ST"}
  "address" : "49 MASON ST",
  "location" : { "x" : -122.408986, "y" : 37.783460 },
  "score" : 27,
Is it a NSDictionary of NSDictionaries?
ChanceYohman
This seems to work, but it's not setting up the spatial reference correctly:
NSDictionary *sRJSON=[NSDictionary dictionaryWithObjectsAndKeys:@"4326", @"wkid", nil];
    NSDictionary *locationJSON=[NSDictionary dictionaryWithObjectsAndKeys:@"-122.408951", @"x", @"37.783206", @"y", nil];
    NSDictionary *attributesJSON=[NSDictionary dictionaryWithObjectsAndKeys:@"MASON", @"StreetName", @"ST", @"StreetType", nil];
    NSDictionary *json=[NSDictionary dictionaryWithObjectsAndKeys:sRJSON, @"spatialReference", @"1 MASON ST", @"address", locationJSON, @"location", @"75", @"score", attributesJSON, @"attributes", nil];
    AGSAddressCandidate *candidate=[[AGSAddressCandidate alloc ]initWithJSON:json];
    NSLog(@"***Address Candidate Start***");
    //Display the address cey 03.18.10
    NSLog(@"Address Candidate String: %@",[candidate addressString]);
    //Display the location cey 03.18.10
    //What's the spatial reference of the locator? How can I find that out at the endpoint? Wouldn't it make sense to be able to retrieve the spatial reference from the point?
    AGSPoint *location = [candidate location];
    NSLog(@"Address Candidate @ (%f,%f,%@)",[location x], [location y], [location spatialReference]);
    NSDictionary *address = [candidate address];
    NSLog(@"Address Candidate Fields Count: %d", [address count]);
    for(NSString *aKey in address)
        NSLog(@"Key: %@ Value: %@", aKey, [address objectForKey:aKey]);
    NSDictionary *attributes = [candidate attributes];
    NSLog(@"Address Candidate Attributes Count: %d", [attributes count]);
    for(NSString *aKey in attributes)
        NSLog(@"Key: %@ Value: %@", aKey, [attributes objectForKey:aKey]);
    NSLog(@"Address Candidate Score: %f",[candidate score]);
    NSLog(@"***Address Candidate End***");
Output:
2010-06-14 17:20:07.679 AGSAddressCandidate[973:207] ***Address Candidate Start***
2010-06-14 17:20:07.682 AGSAddressCandidate[973:207] Address Candidate String: 1 MASON ST
2010-06-14 17:20:07.683 AGSAddressCandidate[973:207] Address Candidate @ (-122.408951,37.783206,(null))
2010-06-14 17:20:07.683 AGSAddressCandidate[973:207] Address Candidate Fields Count: 0
2010-06-14 17:20:07.684 AGSAddressCandidate[973:207] Address Candidate Attributes Count: 2
2010-06-14 17:20:07.684 AGSAddressCandidate[973:207] Key: StreetType Value: ST
2010-06-14 17:20:07.685 AGSAddressCandidate[973:207] Key: StreetName Value: MASON
2010-06-14 17:20:07.685 AGSAddressCandidate[973:207] Address Candidate Score: 75.000000
2010-06-14 17:20:07.686 AGSAddressCandidate[973:207] ***Address Candidate End***
NimeshJarecha
The spatialReference parameter in your JSON is outSR parameter and not the address candidates spatial reference value.
===For REST help doc===
outSR - The well-known ID of the spatial reference or a spatial reference json object for the returned address candidates. For a list of valid WKID values, see Projected coordinate Systems and Geographic coordinate Systems.
This parameter was added at 10.
Change your code lines as following and you'll see location's spatial reference in the output.
//NSDictionary *sRJSON=[NSDictionary dictionaryWithObjectsAndKeys:@"4326", @"wkid", nil];
    //NSDictionary *locationJSON=[NSDictionary dictionaryWithObjectsAndKeys:@"-122.408951", @"x", @"37.783206", @"y", nil];
NSString *locationJSON = @"{\"x\":-122.408951,\"y\":37.783206,\"spatialReference\":{\"wkid\":4326}}";
    NSDictionary *json=[NSDictionary dictionaryWithObjectsAndKeys:@"1 MASON ST", @"address", [locationJSON JSONValue], @"location", @"75", @"score", attributesJSON, @"attributes", nil];
    AGSAddressCandidate *candidateTest =[[AGSAddressCandidate alloc ]initWithJSON:json];
Hope this helps! Please let me know if you have any further queries.
Regards,
Nimesh
ChanceYohman
Thanks Nimesh.
