AnsweredAssumed Answered
Labelling Parcels
Question asked by malik2013 on Apr 3, 2013
Latest reply on Apr 10, 2013 by ad_giles@hotmail.com
Good Afternoon,
I need help with labeling the Property Parcels.
For the Parcel shapefile, I have two columns in the attributes table, NAME and OWNER_NAME. I am labeling the parcels using the NAME field, however, there are cases where the NAME field is empty but there is a record in the OWNER_NAME field. Now I could simply select the empty fields and then using the field calculator could populate the NAME field.
However, I dont want to do this. I want to use an expression where I could label the parcels using NAME field and if the NAME field is empty then the OWNER_NAME field would be used to label the parcels. How do I do this using either python or VB?
Thank you in advance.
Outcomes
