'Show Table' functionality throws an error - "Accessing data failed"
3370
04-03-2013 11:53 AM
DishaGori
I get an error "Accessing data failed" when I try to use the "Show Table" functionality for my Census Division layer for Population 2006, 2007 or Change layer. It somehow seems to be working for the Census Sub-Division layer.
http://arcgis.com/home/item.html?id=4f710075c0524724bffa61c5da9bbc91
The service is an ArcGIS Server Service and was published using ArcGIS Desktop 10.1.
Does anyone know what could be causing ? Or is this some sort of a bug?
MikeMinami
Esri Notable Contributor
It seems that the query request sent to the service is timing out. Even if I try to send a query directly to the service via the URL below, it doesn't return a response. There may be something wrong with the service.
http://maps.esri.ca/arcgis/rest/services/StatsServices/Population/MapServer/1/query
Mike
RickThomas
Mike -
I am having a similar problem, although it is not consistent.  Sometimes the table will show, but most times I get an error message.Is there any way to examine the file to determine what is causing the error?
File:  http://www.arcgis.com/home/webmap/viewer.html?services=ad6048a8650744868891b6d7cc675374
Rick
MikeMinami
Rick,
I have looked at your web map. It does take a long time for the table to load. This is a general problem with tables currently. We have since made a performance optimization that will go live at the end of the month. Unfortunately, in the mean time, there is no work around for this.
Mike
TomScharmen
I still have problems accessing table with some features, while others on the same map will work.  For example - the Children of Foreign Born Parents feature on this map: http://nmcdc.maps.arcgis.com/home/webmap/viewer.html?webmap=afeac7db53f649be9260c1a53a52eb0a
Have you worked out a way to troubleshoot the table to correct this issue?
thanks
