switch coordinate grid from 0-360°
997
04-03-2013 12:54 AM
AndreaNass
Is there a possibility to switch the coordinate grid from 180°W-180E° --> 0°-360°???
Any help is very wellcome and thank you in advance,
a.nass
MelitaKennedy
Esri Notable Contributor
If you add the attached shapefile to ArcMap first, it will set the data frame to 0-360 in WGS84. If you want to use a different GCS, use the Define Projection Tool to change the coordinate system.
Melita
AndreaNass
Thanks very much! it works.
Now I only still have the problem, that the layer Grid doesn`t show the same coordinates.
They still display in 180°W-180°E
Do you/anybody have a furhter hint for me.
Thank, andrea
MelitaKennedy
Hi Andrea,
Do you mean in layout view, adding a graticule to the map? That functionality was never added to allow it to label 0-360. You might have to create the grid, but unlabelled and label it by hand or use the Create Fishnet tool to generate a graticule, but again it would have to be labelled manually.
Melita
