Can anybody help me with some suggestions as to how to compare schema of two geodatabases through python scripting? What would be the simplest way to approach for this comparison using python code?
You can use the Feature Compare tool to compare feature classes. There is an option to compare only the schemas. You could script it so that you iterate through each feature class in each geodatabase.
